Can someone tell me how to produce a bavel on a base
Results 1 to 5 of 5
Thread: Can someone tell me how to produce a bavel on a base
    Dec 2014
    Default Can someone tell me how to produce a bavel on a base
    Hi
    Now I've finished building My CNC Router (Ox from OOZnest in the UK) I want to get out and cut something, doesn't everyone. I wanted to make an Axidraw clone (Plotter), but one with wooden fittings instead of plastic as I thought it looked more cool. Cutting the pieces isn't that hard but the base or plynth is a bit of a headache.
    It needs to be 600mm long and 127mm wide and have a bevel or rounded edge at the the top and another bevel at the bottom. Its the bevels I don't no how to add into the design and get the router to cut it.
    Something like the 2 attachments would be what I wanted the first one around the top and the second around the base, something similar to a picture frame.
    Please let me know what you think.
    Thanks a lot.
    Attached Thumbnails Attached Thumbnails Can someone tell me how to produce a bavel on a base-46725fb3-70be-47f6-b666-e7a36bdb4866-jpg   Can someone tell me how to produce a bavel on a base-bvnew-gif
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    Default Re: Can someone tell me how to produce a bavel on a base
    Once you designed the part, it could be cut with a cnc router with rough cut first, then finish cut with a ball end bit/mill fairly easily, but may take a bit. You can also use standard router bit in your cnc spindle/router. But in my opinion, there are times when simpler techniques are faster and easier. In this case a couple of appropriate router bits and simply using a hand router or router mounted in a router table would accomplish your goal in a lot less time and effort (and material) without all the design, setup and fixture/clamping effort. I know... the cnc router is more fun, but...
    Member awerby's Avatar
    Apr 2004
    This is what's called an "ogee" - there are router bits that will cut it in one pass. Here's a set of them for comparison's sake: Detail Router Bit Set - Lee Valley Tools If you need specific-sized features that you can't find anywhere, you can either get a tool custom-made with that profile (which isn't as expensive as you might think) or figure out how to get a combination of ball and flat-end bits to cut it. I agree with Coherent above; this is a project which would probably be easier to do with a regular router table; you don't need CNC for this.
    Dec 2014
    Yes I was thinking the same thing. Use a board with a hole in it and a router trimmer underneath and finish the bevel on that.
    I'll try that out.
    Thanks a lot for the reply.
    Dec 2014
    Thats nice
    If I had to pick one it would probably be the Double Curve Bit.
    Actually I just wanted to make the plynth a little less like a plank of wood. So I'll go with Coherents suggestion.
    Thanks.
