Proper Lathe Technique
Results 1 to 3 of 3
Thread: Proper Lathe Technique
    Oct 2006
    Default Proper Lathe Technique
    Need to ask you experienced machinist which method produces the best results or does it matter.
    When writing gcode to turn stock to a specified depth which, for example, will take 3 passes at a full cut and then there is a small amount needed to cut to a final dimension. Should you take the partial amount first and then the full passes or full passes and then the partial? Work hardening issues?
    TIA
    RT
    Member awerby's Avatar
    Apr 2004
    Default Re: Proper Lathe Technique
    Usually, you'd take the heavy cuts first, and then a light one as a finishing pass. But if the material has work-hardening issues, like some stainless alloys, then it may need a heavy cut to get under the work-hardened layer instead of just rubbing on the surface.
    Aug 2014
    Sometimes a light finishing cut doesn't leave a good finish - especially with carbide tooling on stainless steel. Under a magnifying glass you can see rough patches interspersed with bright shiny patches. Carbide tools are often not very sharp, and don't like a shallow cut. I have also learned that when using soluble oil flood coolant, increasing the oil concentration from the minimal 7% to 15% gives a better finish, noticeably on 303 stainless.
