Yes you right ... thanks ...can you tell me which version will works great ?
Sent from my BLACK-1X using Tapatalk
You can start from any tool number, and can call m6 from the toolbar, or MDI as well as g-code.
What version of Mach3? 3.043.022 will hang, due to a bug in Mach3
I tried m6 without any programs after initial auto zero but it hanged after reaching tool change position
UCCNC 2017 Screenset
Try 3.043.062.
Hii Gerry ...
Thanks a lot for helping me out it works .great job and great work ....
Well one thing I want to ask I used to tool program it work fine after tool Changes spindle is not start automatically. What can I do for this I searched in screen but I found only one settings related to spindle settings in tool change tab and its unchecked now for automatic start ..
One more thing it works great with program but if I use keypad to move machine axis they respond late and screen also behave to slow when regenerate ..what would be the problem ....thanks again .... screen set working nice but these problems arise ...I don't know the second problem is related to screenset or not ... please guide me ...
If you have a large file loaded (>200,000 lines), then turn off the toolpath display.
If you have a small file loaded, then your PC is not powerful enough.
The 2010 screensets larger toolpath display uses more resources than the default Mach3 screen.
Ok thanks ....and what about spindle autostart after m6 ...there is any setting which is missing....
You probably need to add an M3 in your G-code, after the M6.
Hello sorry for butting in. do you no were i could find information or photos on wiring a touch probe to a PRT-E1500W. Thank you.
