Ultimately you need to know the clamping force on your chuck, then the cutting forces that you are going to be applying to the workpiece. C110 can range in hardness from B50-B95 or so so your surface speed will be affected too. At 9" Diameter you start surpassing your SFM max in Carbide around 600RPM, so any faster and you're not doing yourself any favors.
