I run Mach3 in my new 3 axis 4 motors table router cnc and for the first time I use ESS interface instead of the parallel port, my experience before has always been with the printer port. I run a NC code (has a lot of curved patterns and straight lines for testing the new machine) which I used back in 2018 and was working very good then but now it cuts straight lines perfect but when it hits curves the cuter moves in steps of about 1/8”, kind of jerky I would say. This code in the past used to cut the curves fast like straight lines.
I tried different NC codes I have from the past and all are the same.
I wonder if anyone knows what the problem is, perhaps since I’m new to ESS I missing some setting(S)
