So as the title says, I'm running mach 3 and sometimes the software gets stuck when loading a gcode file at generating the toolpath. It looks like it's consistently hanging at one of the first few lines, a G20 command. I have to click cancel on the toolpath losing, click stop, then regenerate toolpath, and finally twins the gcode. Sometimes it loads just fine.
Any ideas?
Sent from my Pixel 3 XL using Tapatalk
The machine is set up in inches.
I am using the post processor for Mach 3 from Autodesk Fusion 360, and this G20 is being created by the post. Isn't it a good idea to always call out your units?
(MACHINE)
( VENDOR AVID CNC)
( DESCRIPTION AVID CNC 96X96 ROUTER)
(T1 D=0.375 CR=0. - ZMIN=-0.05 - FLAT END MILL)
G90 G94 G91.1 G40 G49 G17
G20
M09
G91 G28.1 Z0.0
G91 G28.1 X0 Y0
G28 G91 Z0.
G90
(TRACE1)
M5
T1 M6
S24000 M3
G54
G0 X82.25 Y72.9902
G43 Z0.9 H1
Z0.5
G1 Z-0.05 F200.
X83.5
Z0.5
G0 Z0.9
(FINAL CUT)
G0 X-0.0625 Y39.9802
Z0.9
Z0.5
G1 Z0.4 F13.3
Y42.5323 Z-0.05
Y72.8457 F200.
G2 X0. Y72.9854 I0.1875 J0.
X-0.0625 Y73.1252 I0.125 J0.1398
X9.125 Y82.3123 I9.1875 J-0.0004
X9.2646 Y82.25 I0. J-0.1875
X9.4045 Y82.3127 I0.1399 J-0.1248
G1 X72.8406 Y82.3123
G2 X72.9801 Y82.25 I0. J-0.1875
X73.12 Y82.3127 I0.1399 J-0.1248
X82.3123 Y73.13 I0.005 J-9.1873
X82.2499 Y72.9903 I-0.1875 J-0.0001
G1 Y72.9901
G2 X82.3123 Y72.8504 I-0.1251 J-0.1397
G1 Y9.4045
G2 X82.2499 Y9.2649 I-0.1875 J0.
G1 Y9.2647
G2 X82.3123 Y9.125 I-0.1251 J-0.1397
X73.1248 Y-0.0625 I-9.1875 J0.
X72.9852 Y-0.0002 I0. J0.1875
X72.8457 Y-0.0625 I-0.1396 J0.1252
G1 X9.4077
G2 X9.2679 Y0. I0. J0.1875
X9.1282 Y-0.0625 I-0.1398 J0.125
X-0.0625 Y9.1218 I-0.0032 J9.1875
X0. Y9.2616 I0.1875 J0.0001
X-0.0625 Y9.4013 I0.125 J0.1397
G1 Y42.5323
G0 Z0.9
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
Yes that is not very good, if you can change the Post Processor it may help, or if you can edit the Post, it would be even better. You don't want to be using a G28 G91 this is an incremental move, your program is G90 absolute so it is best to keep all moves the same, canned cycles are incremental, and are canceled with a G80 usually placed after the Drilling operation, there are other canned cycles not just for Drilling, this is just ( 1 ) of them
As you can see in the program after you use a G28G91 you have to then use a G90 or you would crash
G20
M09
G91 G28.1 Z0.0
G91 G28.1 X0 Y0
G28 G91 Z0.
G90
G1 Y42.5323
G0 Z0.9
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
G17 G40 G80 ( first line this is all that is needed, Do this by hand and try it, there may still be some changes that it needs keep it simple is best )
G90
G0Z0.
G0X0Y0.
G54
T1M6
M3S24000
G0 X82.25 Y72.9902
End of Program
G1 Y42.5323
G0Z0.
G53X0Y0.
M5
M30
Mactec54
