Mach 3 Homing the wrong way
Results 1 to 3 of 3
Thread: Mach 3 Homing the wrong way
    Feb 2013
    uk
    Default Mach 3 Homing the wrong way
    I'm just refurbing an earlier build and upgraded to proximity switches, using the existing Gecko 540 and 4 x Nema 24’s.
    I put four NPN proximity switches on it, 2 on the Y, one of the X and one on the Z. When I press Ref All Its homing to the top on the z fine but then heads off up the Y away from the front. I want to reference/home front left standing at the machine. Here’s a couple of screen shots. I ticked and unticked a combination of both these screen but it to no avail. Am I just looking in the wrong place
    Mach 3 Homing the wrong way-screen-1-jpgMach 3 Homing the wrong way-screen-2-jpg? Mach 3 Homing the wrong way-cncz-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Mach 3 Homing the wrong way
    The menu shown in your screenshot controls the general direction of movement. Set it so that the machine moves correctly when you press up/down/left/right/PgUp/PgDown keys.
    Homing is set up in Config - Homing/Limits menu. There is a tick mark labeled "Home Negative".
    P. S. Also, your pin numbers don't seem to be set correctly.
    You said you have 1 switch on the X axis - then why do you have both X++ and X-- set in the menu? Same goes for the Z axis.
    On the Y axis, do you have one switch on each side of the portal? Why are they both wired to the same pin? That could make automatic squaring of the portal a bit problematic. Also, same problem with Y++ and Y--. You really have home switches, not limit switches, so it would be best not to use X++, X--, Y++, Y--, Z++ and Z-- at all.
    Feb 2013
    uk
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks. Very good andswers and questions. I had totally forgotten about the Homing/Limits menu, dhoh!. This is a sign that working at low temperatures does not always make for rational descision making at the end of the day ha. I have motor on Y axis and slave the A xis to it, giving two motors on the Y. Your right i'll uncheck lots of these switches. Thanks!
