A Axis
Results 1 to 2 of 2
Thread: A Axis
    Member BJM737's Avatar
    Oct 2019
    Default A Axis
    I have added a stepper motor to my machine and enabled it as axis "A" in mach 3, Does anyone know how I can get the "A" axis stepper motor to rotate continuously? using G-Code? How can I set the speed? I have a stepper motor that has 0.6 Degrees per step.
    Member awerby's Avatar
    Apr 2004
    Default Re: A Axis
    If you want to do 4-axis machining, simply mounting a stepper to your mill's bed isn't going to help much. You really need a rotary table with a substantial gear ratio to withstand cutting forces that will tend to overpower the stepper. G-code commands don't tell steppers to rotate continuously, although you can direct it to advance to a large number of degrees. If you wanted continuous motion, it would be better to set it up as a spindle rather than an axis, and use M-codes to control it, using PID to set the speed. Usually a different sort of motor would be used for that, not a stepper. Or you could start with a lathe rather than a mill or router.
A Axis
A Axis
