Need Help! Auto Tool Zero Script for Mach3 043.066
Results 1 to 2 of 2
Thread: Auto Tool Zero Script for Mach3 043.066
    klys's Avatar
    Dec 2019
    Question Auto Tool Zero Script for Mach3 043.066
    Hey there people!
    I having a compatibility problem with old scripts for Auto Tool Zero.
    This script come with the cd of the cnc machine genmitsu cnc router 3018-mx3
    Code:
    'Rem	Probe Down by PEU (Based on Erniebro Work)
    FeedCurrent = GetOemDRO(818) 	'Get the current settings
    ZCurrent = GetDro(2)
    Code "G4 P1"			'Pause 1 second to give time to position probe plate
    Code "F100"			'slow feed rate to 100 MM/MIN
    GageH = GetOEMDRO (1002)
    Rem	Probe Down by PEU (Based On Erniebro Work)
    ZCurrent = GetOemDro(802)
    Code "F100"			'slow feed rate to 10 MM/MIN
    GageH =19.7                     'Tool tool height requires actual measurement
    ZNew = ZCurrent - 30		'probe down 30mm
    Code "G31 Z" &ZNew
    While IsMoving()
    Wend
    Call SetDro (2,GageH)
    FinalMove = GageH * 1
    Code  "G0 Z" &FinalMove
    Code  "G0 Z" &25                'This number is greater than the height of the tool setting tool
    Code "F" &FeedCurrent  		'restore starting
    its work fine in mach3 042.040 but prompt error on the new version (043.066)
    i also found another script with the same issue
    Code:
    Dim Ztemp, SpeedCoarse, SpeedFine, SpeedRetract, MoveCoarse, MoveFine, RetractCoarse, RetractFine,TouchPlateHeight
    SpeedCoarse=100
    SpeedFine=10
    SpeedRetract=300
    MoveCoarse=-10
    MoveFine=-0.8
    RetractCoarse=0.2
    RetractFine=5
    TouchPlateHeight=0
    If IsSuchSignal (22) Then
    	Ztemp=GetOEMDRO(180)+MoveCoarse
    	code "G31 Z" & Ztemp & " F" & SpeedCoarse
    	While IsMoving()
    	Wend
    	Ztemp=GetOEMDRO(180)+RetractCoarse
    	code "G00 Z" & Ztemp & " F" & SpeedRetract
    	Ztemp=GetOEMDRO(180)+MoveFine
    	code "G31 Z" & Ztemp & " F" & SpeedFine
    	While IsMoving()
    	Wend
    	Call SetDRO(2,TouchPlateHeight)
    	Ztemp=RetractFine
    End If
    Can someone give me any other script which work for the last version of mach3? Please
    I cant engrave with the g code generated by easel because the version of the script is for the last version but my Auto Tool Zero Script is not working on the last version.
    Thank in advance to who read/reply this post.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Auto Tool Zero Script for Mach3 043.066
    Version 3.043.066 is known to be very buggy. The version on the Machsupport website is now 3.043.062. I would try installing that version.
    UCCNC 2017 Screenset
