Need Help! Mach3 One stepper motor won't move
Results 1 to 5 of 5
Thread: Mach3 One stepper motor won't move
    Member dbulldog62's Avatar
    Nov 2019
    Default Mach3 One stepper motor won't move
    I am replacing my computer on my plasma table. I loaded Mach3 on the new computer set it up with the same setting as the old one. Everything works as it should except one of my motors on the Y axis won't move. I plug in the old computer works fine. HELP!
    Member number40Fan's Avatar
    Nov 2019
    Default Re: Mach3 One stepper motor won't move
    USB or parallel port?
    Nov 2019
    Quote Originally Posted by number40Fan View Post
    Parallel port
    Nov 2019
    Double, triple, quadruple check the pin layout in Mach 3. If that doesn't work, can you swap the ports between the two computers?
    Member Sterob's Avatar
    Jan 2007
    You have 2 Y axis Steppers?
    Have you set one to slave to the other?
