Problem Mach3 Partial Lockup - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Mach3 Partial Lockup
  1. #13
    Member vkonradi2's Avatar
    Nov 2019
    Default Re: Mach3 Partial Lockup
    Added the leading and trailing % lines. Each is %CRLF specifically. Ran the operation sequence 3 times and it failed on the 3rd run. Same symptom, all moves executed but the spindle-off command not executed and hung. So yeah it is one of those nasty intermittent things. Unfortunately did not respond to the % lines.
    I think I'll chop down the sequence, investigate if there is any dependence on length of the move sequence. If I can pare it down to a manageable size that executes quickly (and still fails) I can iterate on experiments without waiting hours of machine time. Maybe experiment with adding delays before the spindle-off command.
  2. #14
    Jan 2005
    Quote Originally Posted by vkonradi2 View Post
    How do you have the M5 On / Off controlled Relay or some other method, if you are having an electrical fault then it won't move past that point until it is completed
    Are you switching a VFD Drive On / Off
    A snip of your wiring would help could even be a Noise problem
    Mactec54
