Hey everyone!
I need a little help with an issue im having with my mach3/machine. I built the machine myself and i have everything connected and working okey when i use my laptop (the parallel port is connected to a USB) + the system is wondows 10, the machine works perfectly fine.
I tried switching to a pc which had a windows XP and used the parallel port without the usb connector because the pc already has a place for it, and the machine didnt work. Also had the (VB failure, check system) error popping but disappears randomly, the machine still not working.
I reinstalled mach3 3 times (and yes i did restart the pc after uninstalling and before opening mach3).
As i said everything is wired correctly because it worked on my laptop but didnt on my pc.
Any help would be appreciated!
