Need Help! G Code to continuous run fourth axis in the back ground
Results 1 to 6 of 6
Thread: G Code to continuous run fourth axis in the back ground
    Nov 2005
    Default G Code to continuous run fourth axis in the back ground
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: G Code to continuous run fourth axis in the back ground
    You could configure it as a spindle, but then you'd need to control your regular spindle manually.
    UCCNC 2017 Screenset
    Nov 2005
    Is that easy to do?
    Member awerby's Avatar
    Apr 2004
    You might try detaching the 4th axis from your system and powering it separately. Sherline sells an autonomous rotary table that doesn't need a computer to run: https://www.sherline.com/product/870...table-indexer/ I don't think it has a "continuous" mode, but you could, for instance, tell it to go to 360,000 if you wanted it to rotate a thousand times.
    Nov 2005
    Thanks all I think i got it worked out in the G code. Not quite how i was hoping but it will do.
    Jun 2010
    Normally I let Mach3 drive the 4th axis with Step/Dir signals, but sometimes I want the 4th axis to behave like a lathe. So ...
    I use a single Mach3 output pin to switch between the Step/Dir pins and an external free-running oscillator and a direction switch. The latter does not require any effort from Mach3, and can be invoked from within a program. This works fine.
    However, switching back from 'lathe mode' to controlled mode is more difficult if I want to return to the original orientation. I would need to write a macro to keep stepping until the Index pulse was asserted, and to then zero the A axis. (This is possible.) So far I have avoided this need.
    Cheers
    Roger
  7. #7
    LCB's Avatar
    Aug 2019
