New Machine Build Issue with A-axis on Chinese Workbee Stb5100
Results 1 to 3 of 3
Thread: Issue with A-axis on Chinese Workbee Stb5100
    May 2019
    Default Issue with A-axis on Chinese Workbee Stb5100
    Just built a Workbee 1x1m and tried motor movement. Having an issue that A-axis is making loud rattling noise like GRRR. You would hear such noise if you would drag a lead screw perpendicular across a metal edge.
    System is Win10 Laptop hooked via usb motion controller Stb5100 running Motor Driver Board TB6600.
    For this I realize I need to have a manufacturer usb driver but it was not supplied. I am using a usbmach.dll I found online.
    X and Z axis motors are turning normal and moving the head. When I try to jog in Y direction A-axis (screw) is not rotating but rather oscillating turning clockwise/counterclockwise and making a loud noise. Y-axis and A-axis motors are a twin pair supporting Y dir movement of gentry. When I disconnect A-axis motor, Y-axis motor and movement works fine.
    I have made A be slave to Y. Other than non original usb driver and maybe incorrect Mach3 setup I am not sure what could be an issue here. A axis is coupled well to lead screw, and screw is moving freely when machine is powered down.
    Wondering if anybody came across anything similar?
    Member Sterob's Avatar
    Jan 2007
    Default Re: Issue with A-axis on Chinese Workbee Stb5100
    Try disconnecting the Y and A axis steppers from the ball Screws ( lead screws?) and observe how they behave. Do they turn in the correct directions and run at the same speeds?
    Jul 2016
    Slovenia
    Quote Originally Posted by Workbee1x1 View Post
    Hi, I have bulit Chinese Workbee 1500mm x 1500mm, with same STB5100 controller and TB6600 driver board. But I can't set slave axis ( A to be slave to Y) in Mach3. I can move them independently, but slave axis option doesn't work. I use BL-UsbMach.dll plugin, that came with machine. I tried with usbmach.dll also but i think it is the same plugin. What version of Mach3 are you using? Can you send me ports & pins settings for Motor Outputs and Input Signals? I know that this is not answer to your question but I can't find any other solution. Thanks.
