Question on Mach3
Results 1 to 10 of 10
Thread: Question on Mach3
    Activation process Geeten's Avatar
    Oct 2018
    Default Question on Mach3
    Hello can anyone please tell me that I brought TB 6600 drivers , NEMA 34 stepper motor 35kg and a mach3 interface board. The Dro of mach3 is running but motors not. Please tell me is this problem in connections or something else. And please tell me how to do connections in between motors , drivers , and interface board. Thank you
    Sent from my era_4G using Tapatalk
    Default Re: Question on Mach3
    there are many tutorials on youtube about the step for step setup with mach3. in my experience the best thing in the beginning is work through a tutorial. then your machine should work.
    michael
    Oct 2018
    Quote Originally Posted by neptunier View Post
    michael
    Hi can you prefer me some videos. I can't find the perfect solution for it. Thank u
    Nov 2013
    you'll get more response from the Machsuport Forum.
    Craig
    Member decara's Avatar
    Dec 2018
    vbjkk
    Dear Master..
    need Your Help..
    How to Make Mach3..can Recall Programe (Auto Selecting and auto start use triger from switch)
    Example :
    We have 5 Programe and 5 Switch Push Button
    Programe01
    Programe02
    Programe03
    Programe04
    Programe05
    Switch1
    Switch2
    Switch3
    Switch4
    Switch5
    Switch1 can Call Programe1 only
    Switch2 can Call Programe2 only
    Switch3 can Call Programe3 only
    Switch4 can Call Programe4 only
    Switch5 can Call Programe5 only
    Pls Help Master
    Thank you
    Decara
    Nov 2013
    you'll get more help on the Mach forum.
    I use Mach4, and I could write a script for doing as you want in Lua. I imagine that you could do the same with Mach3 and Visual Basic
    but I hate Visual Basic....in fact that's the main reason I went to Mach4 in the first place.
    Craig
  7. #7
    Jan 2018
    United Kingdom
    Quote Originally Posted by Geeten View Post
    You likely sussed it by now but in these kind of situations for me it's something to do with Enable. Either wiring or pin selections.
  8. #8
    Sep 2005
    Your going to have to get wiring information, connections for the drivers and Mach3 board, same for steppers. Do some research and then draw out a diagram. What are you
    trying to build and do you hav Any Experience at all in CNC?
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  9. #9
    Dec 2018
    vbjkk
    Craig
    Thank you very much Master..
    Please information Mach4 Last Version?
    Decara
  10. #10
    Dec 2018
    vbjkk
    Dear Master MACH3
    i have one more Question ?
    Please need Your Help
    Example :
    Home Position X0, Y0 , Z88
    WE JOG go to X-50 (F1000) , Y-70(F5000) , Z5(F500)
    How to Can Save above data X,Y,Z Automatically to Programefile and Can Automatically Draw to Display_from Home Position
    i Need Link Tutorial or sample Tutorial
    Decara
Question on Mach3
Question on Mach3
