New Machine Build Dental 4-axis machine + mach3
Results 1 to 4 of 4
Thread: Dental 4-axis machine + mach3
    Activation process Franko123's Avatar
    May 2018
    Default Dental 4-axis machine + mach3
    Hello, my colleagues!
    At first: sorry for my non-professional vocabulary. This is the first time when I face this problem and specialists in this field.
    My story in a few words: I am a dentist. We purchased a machine for milling crowns and bridges Wieland 4030 (as I understand built on the basis of ISEL 4030, 4 axis) When we got it, we realized that there was a problem with connecting. After many attempts, we sent to a repair center where it was accepted the decision to replace the old controller and servo drives with new ones. After the upgrade, we got a machine that is fully driven by MACH 3, but now we are in search of a program that can generate for the Mach3 CNC file.
    I install on my computer PowerMill 2017, but I have no idea how to connect it with my CNC.
    As well, I have downloaded the dentist version of PowerMill DentMill (the project had been closed in 2015).
    The main task is to mill crowns and bridges in 4 axes with an auto-change tool(we used 3 milling burs). We simulate crowns in the CAD program, and then we get an STL file. After that, it needs to be milled.
    I attach a photo of the machine to the post.
    I ask your advice in this case. For any information and direction I will be very grateful. You are my last hope. Thanks!
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Dental 4-axis machine + mach3
    You don't connect Powermill to Mach3.
    You create toolpaths in Powermill, and export g-code.
    You then load the g-code into Mach3 to control the machine.
    UCCNC 2017 Screenset
    May 2018
    Quote Originally Posted by ger21 View Post
    Gerl, Thank You for the answer.
    Sorry for incorrect description.
    How should i create toolpaths for Mach3 in my case? (coordinates, choose tools).
    Dec 2013
    This would be a good place to start.
    Jim Dawson
    Sandy, Oregon, USA
