I am trying to access the PWM port of my breakout board for spindle control using BL-USBMACH. Everything is OK with the machine except the Spindle control using the PWM or VFD. If you have experience with the board, kindly let me have the MACH3 setting Pin#, Port# and other configuration to control the spindle.
The board is attached.
- needed:mach3 plugin dll for USBMach V2
- Newbie- Mach3 not controlling PWM of BL-USBMach Break out Board of Chinese CNC3040 Machine
- BL-USBMACH-2.1 Limit and Homing Wiring
- Quick Change Spindle Adapter for Chinese 2.2kw Spindle? Spindle acronyms?
- Spindle motor set,1pcs 2.2kw spindle + inverter+ spindle mount bracket+ER collet
Mactec54
