Auto tool zero in MM on mach3 for a touchprobe script needed
Results 1 to 2 of 2
Thread: Auto tool zero in MM on mach3 for a touchprobe script needed
    Dec 2017
    United Kingdom
    Thumbs up Auto tool zero in MM on mach3 for a touchprobe script needed
    Hi
    Many video on YouTube showing the script in Inches
    But i want to make a touch probe soon, and i cant find the script to set it in mm
    does anyone have the script in mm
    so i can copt it and alter the settings in mm please?
    pretty please
    Registered dharmic's Avatar
    May 2015
    Default Re: Auto tool zero in MM on mach3 for a touchprobe script needed
    Does it care? If Mach3 is set up in mm and either there's no G20 (units in inches) in the program or you change it to a G21 (units in mm) then you should be fine. Post up a sample script and we can double check, if you like.
