Need Help! Is it possible to get Mach3 full version for free?
Results 1 to 8 of 8
Thread: Is it possible to get Mach3 full version for free?
    Apr 2018
    Default Is it possible to get Mach3 full version for free?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Is it possible to get Mach3 full version for free?
    No
    UCCNC 2017 Screenset
    Jun 2017
    Of everything I've purchased to get my cnc router up & running I think Mach 3 was one of the least expensive items I've had to buy & I didn't think it was expensive for what it does.
    Apr 2014
    Mach3 is not and will never be developed any further.... Consider alternatives at least such as uccnc which cannot be beat on cost
    http://cncdrive.com/UCCNC.html
    Note.... You will need a UC motion controller as uccnc will not work on any other motion controller... And you can always flip back to mach3 or mach4 with the UC motion controllers no problem
    It's an option to at least consider to have that flexibility and use something that is actively being developed
    Jan 2005
    If you want a free controller software there is always linuxcnc. If you don't have a machine that needs Uber high step rates you can also look at grbl, which runs on an Arduino uno. There are many interfaces for it on many different platforms.
    Member CitizenOfDreams's Avatar
    Nov 2012
    I bought Mach3 a few years back when there was not much else that could compare to it. I think it's still worth buying today if it does what you need. It is certainly one of the cheapest parts of a CNC machine, as Gary-Wiant said.
  7. #7
    Member mintz's Avatar
    Jan 2004
    Quote Originally Posted by CitizenOfDreams View Post
    Universal gcode sender is free
  8. #8
    Apr 2012
    Australia/China
    Hi , You can use the demo version as long as you like , but limited to how much G code you can use. Good to test your machine to make sure all is ok with mach3 before you purchase.
