Problem Lazycam pockets problem
Results 1 to 1 of 1
Thread: Lazycam pockets problem
    *Registered User* Sergiorods's Avatar
    Sep 2018
    Angry Lazycam pockets problem
    Dear all,
    I'm using the Lazycam on my new 3040 and while I was milling same basic things, no problem. Problems started when I tested the first pocket on a DXF that was already used to mill the external contour.
    On Pic1 you can see a basic DXF mill on the external contour. No problem to create the Gcode.
    On Pic2 I've disabled the external layer and created a pocket with tool 2mm. Visually looks normal (I think) but when I press Post Gcode, the message is "Posting file complete" but no file is created.
    I can't believe that all the users have this problem. Anyone knows any solution to it?
    I'm using Windows XP 32 bits and Lazycam 3.00.
    Thank you in advance.
    Regards,
    Sérgio
    Attached Thumbnails Attached Thumbnails Lazycam pockets problem-pic1-jpg   Lazycam pockets problem-pic2-jpg
