Hi racetech,
Do you know about GCode Fixture offsets?
Regards
hello all im new to cnc have ran a sign cutter plotter for years have alot of drawings i would like to convert to gcode,i use coral draw and flexisign and save files to dxf .i have a ton of vector art that is all custom and would like to convert to gcode and run on cnc mill .im not looking for free i will pay for somethig that is easy to use for a beginner.i have cut a few things out as far as true type text and samples of things i found on here.i have downloaded many trial versions to try but no real success.im throwing up the white flag....i have tried this https://www.cnctoolsworld.com/applic...r_free-2.html# when i try to run it, it will start the milling but not showing up on the table as a whole to mill way off to one side in mach3 no matter what i do to the xyz axis and zero out and hit regen in mach3 i have home switches and soft limits all working as they should.. in the software on the second setting it has values to enter if you want a change that i think is where my problem is ... i will up load some screen shots in a few ..this software i came across is free but like i said im looking for something i can use as a beginner and this i tried and to me seemed very nice and simple any input will be great ..
please go to link and see they have screen shots on the software take a look at the 02 settings that is what i think the problem is with my gcode.
Hi racetech,
Regards
Regards
TK http://dynomotion.com
i have geko g540 4 axis controller.percission mathews mill with vfd running a 3phase motor.
i dont know too much on gcode been reading all i can to learn . i got all this stuff in a box and never knew anything about cnc setting up just to get running was a real job.countless hours to get all to work together...i can build one hell of a race car with my hands but this mill stuff is all new dice to me ,but i like it and it will get my son somethin to learn also instead of video games LOL..
I cant believe nobody has any input on this ?
You didn't give enough information for anybody to know what the issue is.
Plus, I doubt that anyone reading this has used that g-code converter before.
Post the .dxf file, and the g-code.
A screenshot of Mach3 might be helpful?
UCCNC 2017 Screenset
