Problem Positive home issue
Results 1 to 2 of 2
Thread: Positive home issue
    Dec 2016
    Netherlands
    Default Positive home issue
    Hello,
    I have converted an XpertMill to run under mach3. I use the limit switches as standard on the machine. That means Y must home to its +1000mm pos. I have set positve homing and the home offset to 1000.
    Now the machine runs positive to the switch, want to back of competely to 0 and then slowly to 1000. How can I set that it backs of only to 990 or so and then slow to 1000again?
    Kind regards
    Ronald
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Positive home issue
    You must be using a custom home macro. By default, Mach3 should only back off until the switch opens, and not do any movement at all.
    UCCNC 2017 Screenset
Positive home issue
Positive home issue
