Need Help! Mach3 on cnc punch
Results 1 to 5 of 5
Thread: Mach3 on cnc punch
    Oct 2017
    Default Mach3 on cnc punch
    Hi everyone.
    I have a retrofitted cnc punch with Mach3,and i have problem running gcode from cnckad cad cam software on mach3.
    Any advise about how to run gcodes for punch press on mach3?or how to edit post processor file from cnckad to run on mach3?
    Appreciate your help
    Dec 2003
    Default Re: Mach3 on cnc punch
    Thread moved to Mach forum.
    Dec 2003
    I assume you have X - Y part positioning hardware in place, if so it is usually a easy task of positioning material in the X & Y and then issue the M code to trigger the punch.
    Oct 2017
    Quote Originally Posted by Al_The_Man View Post
    When i enter X Y axis coordinates in the gcode the table moves but away from the punch ram,how can i adjust the machine coordinates?
    What is the m code to trigger the punch?
    Thank you for your help.
    Feb 2016
    Indonesia
    Hi, Anyone can help share post processor(machines file) for Amada 355 in cncKad software? help and email to: Lasmian81@yahoo.com .thks
Mach3 on cnc punch
Mach3 on cnc punch
