I'm an engineer that just started working with a cabinet shop using an SCM Record 125 and am having some difficulty with tool length settings varying between the 1/2" and 3/16" tools on the machine for the same depth of pocket in the CAD model. I'm looking for a way to set this in on the Record 125. Hence, the manual request. Thank you in advance.
should look into your cam program like Xilog plusI'm an engineer that just started working with a cabinet shop using an SCM Record 125 and am having some difficulty with tool length settings varying between the 1/2" and 3/16" tools on the machine for the same depth of pocket in the CAD model. I'm looking for a way to set this in on the Record 125. Hence, the manual request. Thank you in advance.
