- Configuration of a bender in the Y1 axis parameter ADIRA PA02512
Dear good night,
This is an ADIRA brand bender from Portugal, it is a CNC machine has an ADcontrol10 controller, a year ago the internal battery of the controller was spent, which caused some parameters to be deconfigured, especially the Y axis that makes the only piston not can go up since there is an input that should give 24VDC but due to the deconfiguration it does not give voltage, someone will know how to activate the parameters for this Y axis.
Some photos are attached and the manual of the equipment I mention is also attached, as seen in this manual there is no description of errors, emergency codes and no configuration parameters, only some basic parameters at the user level, however someone with more experience could you support meAttachment 461477Attachment 461481Attachment 461477Attachment 461479Attachment 461477Attachment 461479
Este es el link del manual
https://www.dropbox.com/s/3qh9z5c53o...rimax.pdf?dl=0
Re: Configuration of a bender in the Y1 axis parameter ADIRA PA02512
Se mueven algunos ejes pero falta la configuración
Y1Type of motor 1
Type of reference 0
Encoder card 1 2
Analog card 1 205
no se si son valores correctos
- You may not post replies
- You may not edit your posts
Forum Rules
