- Fidia C20
Fidia C20
Hi everyone,
I'm working for my company on a new project witch is to adapt a laser on a existing machine. This machine is a JOBS/Linx and the control panel is a FIDIA C20
So I need to find a way to trigger the laser on/off with Gcode. Better could be to have a PWM value to control laser power.
For the moment I'm figuring to use M08 and M09 Gcode command witch is start and stop coolant.
So, in one of the electrical cabinet and with help of all schematics I found some cnc output (on 6ES7 322-1BL00 digital I/O ). Some out put are marked as "available" and i' would like to map M08/M09 to on/off of this output.
So I'm looking for service manual or any information that can help to setup the Fidia software to catch M08/M09 Gcode and apply them to selected output.
Anyway, thank you for reading me.
- Fidia C20
- You may not post replies
- You may not edit your posts
Forum Rules
