- Need Help!- Tool Change Program
Tool Change Program
I have a Kent USA Model TW-32-MV with Fanuc 0MD control. This machine arrived with out manuals. The tool change program O9001 has been deleted.
Anyone have a copy ??? Or a copy of the Operating masnual for this machine.
Kent USA ??? No luck.
Re: Tool Change Program
In Fanuc control, M6 is the tool change command.
For example, after the T01 finished machining, it is programmed to a tool change position by
G28 G91 X0 Y0 Z0;
and then if you want call T2, the programmed as follow:
T02;
M6;
For your case, you have to check what's the next tool should be called. hope this could help to you.
Do you know for sure that it had a O9001 program for tool change? Some machines run the tool change completely out of the PMC. In that case you won't see a 9000 series program. Doesn't need it.
What happens when you type in M6 like the person above said?
Look at parameter 0240. Does it have a number 6 there? That parameter states what M code number will call macro or program 9001. If nothing is there then you likely do not need a 9001 program for tool change.
Here is a tool change program off my YCI Supermax Fanuc OMC. Not sure it will work.
O9001
G0G80G40M9
G91G28Z0M19
M6
G90
M99
Reason: clarity of statement
- You may not post replies
- You may not edit your posts
Forum Rules
