I need a manual for VFD ZONCN NZ200
Results 1 to 17 of 17
Thread: I need a manual for VFD ZONCN NZ200
    Apr 2018
    Czech Republic
    Default I need a manual for VFD ZONCN NZ200
    Hello everyone.
    I need a manual for VFD ZONCN NZ200.
    I wrote to the supplier. I wrote to the manufacturer and no one answered me.
    Can you help me please?
    Thanks Jirka
    Attached Thumbnails Attached Thumbnails I need a manual for VFD ZONCN NZ200-dsc_2037u-jpg   I need a manual for VFD ZONCN NZ200-dsc_2035u-jpg   I need a manual for VFD ZONCN NZ200-dsc_2001u-jpg   I need a manual for VFD ZONCN NZ200-dsc_1999u-png
    Member mactec54's Avatar
    Jan 2005
    Default Re: I need a manual for VFD ZONCN NZ200
    Quote Originally Posted by jirkamm View Post
    Hello everyone.
    Thanks Jirka
    What is the manufactures name
    Mactec54
    Apr 2018
    Czech Republic
    ZONCN
    Jan 2005
    ZONCN
    What do you need to know about it I don't have the manual but may be able to help
    Mactec54
    Apr 2018
    Czech Republic
    Hello.
    I need to set - "device error" for relay output 1.
    Set to relay output 2 - "device on" output
    For analog output I need to set - output "Current frequency" - 0-10V.
    But it probably doesn't have an analog VDF output.
    Thank you
    Apr 2018
    Czech Republic
    Next, I need to set to control the pump power with an external potentiometer.
  7. #7
    Jan 2005
    I need a clear photo of the low voltage terminals
    And no you would not use any of the relay output for a Pot
    Tell me what your VFD is being used for and what it is driving
    Mactec54
  8. #8
    CNCINDUSTRY's Avatar
    Aug 2019
    guangzhou
    Hello everyone.
    Thanks Jirka
    Hi, I have one, how to send it to you?
  9. #9
    Apr 2018
    Czech Republic
    Hi.
    "And no you would not use any of the relay output for a Pot" (I don't understand this sentence)
    VFD is used to control the vacuum pump power for the vacuum table. I need to adjust the power with a potentiometer. When milling holes and grooves I need to increase performance. I meant to connect the potentiometer and pressure sensor in series.
    Attached Thumbnails Attached Thumbnails I need a manual for VFD ZONCN NZ200-dsc_2001u-jpg
  10. #10
    Jan 2005
    Hi.
    Not a very good photo the +10 AVI and Ground Terminals are what your Pot connects to AVI to the center Pot connection there is also a Jumper or switch that needs to be set J2 to AVI it is beside the terminal block
    There may be a Parameter to set also
    Mactec54
  11. #11
    Jan 2005
    Quote Originally Posted by CNCINDUSTRY View Post
    You can attach it here, open a post, go to Advanced scroll down and attach a PDF File
    Attached Thumbnails Attached Thumbnails I need a manual for VFD ZONCN NZ200-zone-post-png
    Mactec54
  12. #12
    Aug 2019
    guangzhou
    Hi.
    Do you need to controll the VFD dynamically?Then you need a controller which has analog input and output module. Such as PLC.
    The potentiometer and pressure sensor connect to the controller's input terminals, and its output terminal connect to the VFD‘s analog input terminals.
  13. #13
    Aug 2019
    guangzhou
    Awful,size limited.
    Do you need the wiring diagrams? Maybe later.
  14. #14
    Apr 2018
    Czech Republic
    Awful,size limited.
    Please send it to modely.malik@seznam.cz. Max. 20Mb.
    Jirka
  15. #15
    Apr 2018
    Czech Republic
    Yes. I need to dynamically. I told the supplier that I needed it this way. The supplier said - ok.
    I see that I can throw away the VFD.
  16. #16
    Jan 2005
    Your VFD is not different from any other, I'm sure you could do what is needed if you get creative, your sensor would be controlled from your machine control and would output a voltage change to adjust the VFD Drives motor RPM as needed not hard to do at all
    Mactec54
  17. #17
    Apr 2018
    Czech Republic
    It is true. I will have linuxcnc and Beckhoff EL3064 and EL4004 there. That could work.
    Good idea.
  18. #18
    JorgenLagmen's Avatar
    Oct 2020
    HiGood Day! I need the manual also, would it be possible for you to share it to me?
