- Newbie- CNC-1310 Machine Z-Axis keeps going Upwards not into material!
I use inkscape to make simple shape for engraving, makercam to generate GCode for the same, when sent thru grblControl 0.8.4 to CNC-1310 C Machine, it starts engraving normally, on second pass of engrave, the z-axis is moving upwards
not downwards through the material, no engraving!
Many thanks
Which way is the z axis motion going?
Is it positive or negative?
G1 Zxxx or G1 Z-xxx
The normal way is downwards is negative motion (think XYZ plane, Z- is down)
If the Z-axis gcode is negative, your machine is setup wrong, and you need to change the axis direction within grbl.
If the Z-axis gcode is positive, your post processor is setup wrong and you need to change your post processor settings.
Learn to read the gcode
- You may not post replies
- You may not edit your posts
Forum Rules
