I have some manuals for this machine, I owned one a long time ago.
I will try and find them if you wish.
Regards
Hi folks,
I have just purchased an old 80's W-EDM machine and looking for any kind of documentation for this HS100. Priority if possible to find schematics for power supply and all otrher circuitry as well.
I have the users manual in Swedish so I think that part is covered as I read/speak Swedish.
So whatever documentation you may have or can link to would be appreciated.
Cheers
Bengt
Regards
Gday Skeney,
Would you be so kind and have a look for the documents.
Cheers from Sweden
Bengt
Also very much interested in getting a copy of Brother QD-2 or QD-3 software for win3.1(or DOS) on 3,5"FDD or zip archive via e-mail.
Here a heads up, still looking for users manual for the WEDM HS100
Now I have the machine working but still in need of manual to get a grip of all parameters that can be set.
Cheers from Sweden
Bengt
Hello again from Sweden,
Still looking for documentation for this HS-100
Anybody out there who is using or remembers what 'System Constant' in machine setup is for?
I have hand written notes that states this setting to be '3' but would like to know what is stands for.
I have managed to repair a floppy with QD-2 software and would like to get Communications via RS232 Cable working.
If I understand this correctly in QD2 the setting NC is for Brother's proprietary opto-link, is the tape reader setting for RS232 output?
So, how do one setup the HS-100 to do all Communication via RS232 Cable and not use the Opto-Link?
Any hints of how to settings should be in PC and HS-100 are welcome, would like to get comms working and avoid manual G-code Writing on HS-100
Cheers from Sweden
Bengt
Any help in this matter would be very much appreciated.
Cheers
Bengt
Hi folks,
I have managed to get hold of documentation in Swedish for my HS100
Case closed
Cheers
Bengt
There is one document that I cannot get my hands on, with each HS100 there is a document with tables showing feed's and speed's for different brass wires/materials.
Anyone out there that have this document and have the possibility to copy and make PDF of it or willing to send a paper copy via post would be much appreciated.
Merry Christmas everybody
Bengt
Hi can any one record a video working in the machine
I just got one hs-100 and i cant get it working thanks
I'm in a big problem
I want an old machine manual (Brother HS-3100 wire cut machine)
Please if you know any source I can find it from
