I just posted a wiring diagram for the 65BA series in this subforum. It may help you with hooking it up. sorry I don't have the actual manual, just that diagram.
I looking for some manual for this servo amplifier, because I must plug this to PC and sterring from MACH3, but I dont know where are appropriate signals in CN1 connector.
Tinmuk
Any problem can be solved by the proper application of heat!
Did you find a pinout for CN1?
I have tha same amplifier bot no dagram.
BR Stefan
I have traced connections for 68BA servo amplifier. I thing same connections will work for you. Here are the details:
https://www.cnczone.com/forums/maint...22538-cnc.html
