Moriseiki lathe CL-25 Programming Manual
Results 1 to 16 of 16
Thread: Moriseiki lathe CL-25 Programming Manual
    Nov 2010
    mexico
    Default Moriseiki lathe CL-25 Programming Manual
    Hello everybody,
    Does enyone know a link or something to download the programming manual of a Moriseiki CL25 lathe?
    Thanks a lot Bro's
    Feb 2006
    Mexico
    Default Que control tiene?
    David,
    What type of control does this machine have? It should say over the TV screen where you can see the program running.
    Nov 2010
    mexico
    MSC-518
    Sorry 4 the delay
    Feb 2009
    So, you need a fanuc 18T programming manual. I'm sure someone has a PDF. My email won't let me send large files over 30mb..,,
    Registered GONorman's Avatar
    Jun 2012
    David did you ever locate a Fanuc 18T manual? Not that I can help you out...I am searching myself. Thought maybe you could point me in the right direction.
    Nov 2010
    mexico
    no havent =( ..... I decided to learn how to live with out it
  7. #7
    May 2004
    What questions do you have that you think would be answered by the manual?
  8. #8
    Nov 2010
    mexico
    a lot !!
    for instance I want to know how to tap a hole
  9. #9
    May 2004
    You will have 2 possibilities depending on the control and what options have been enabled/installed:
    1)
    G01 Z-1. F0.05
    M05
    G01 Z0.3 M04
    M05
    2)
    G84 Z-1. F0.05
  10. #10
    Jun 2012
    I am trying to set up using live tooling and second spindle. I am assuming the second spindle will be axis B. After setting Z0.0 and making chips when using one spindle, I am lost. The live drill will be drilling when the part is in the second spindle, so do I touch off the drill to face of part in spindle 2, take # from machine position page and put it in Z offset for drill? I have to get the part to the second spindle first and don't have a clue.
  11. #11
    Feb 2006
    Mexico
    I do have the Fanuc 18T manual (all of them Programming, Connection, Maintenance). PM if you still need it.
  12. #12
    Jun 2012
    palestine
    Angry mori seiki tl-1 manual
    i need help with mori seiki tl-1 i need help it shows blackscreen wit red led on the power unit .
  13. #13
    Jun 2012
    palestine
    where can i find a manual for mori seiki tl-1 it shows no screen
  14. #14
    Feb 2006
    Mexico
    If it doesnt show anything on the screen and doesnt show any red leds on the motherboard, even if the red led of the power supply is lit, it is likely a problem with the power supply. If the red leds on the motherboard light up then you should look at them and do the troubleshooting acordingly.
  15. #15
    Feb 2009
    Yasnac or fanuc? What model? Tl1s are pretty old, I've even seen them with pixie tube displays.
  16. #16
    May 2018
    Default Re: Moriseiki lathe CL-25 Programming Manual
    Could i have these manuals please of course only if you still have them, thx
