Floppy disk drives
Results 1 to 14 of 14
Thread: Floppy disk drives
    Member Wjman's Avatar
    Apr 2003
    England
    Angry Floppy disk drives
    Hi all,
    We have 5 Hitachi wire EDMs, and due to them not being in a dust free environment have to replace the floppy disk drives occasionally, we use these to download the programs to, however my boss said that we are being charged £400 a time for a replacement. This is a "rip off" as a conventional FD drive costs about 10 to 15 pounds. I know the Hitachi machine uses an OS different to most makes of machines but surely it can't be that different that we cannot use a "Normal" FD drive as a replacement. Any help or suggestions appreciated.
    Mark...
    Member wms's Avatar
    Mar 2003
    wyoming
    Wjman,
    Why not buy a floppy and give it a go. The worst that could happen is it won't work. Make sure when you install the floppy that you line up pin 1 on the drive with the red mark(pin 1) on the ribbon cable. And I would use a backup copy of my program as not to loss any data. By the way if you don't line up pin 1 it will mess up all the data on your disk. Been there, done that.
    Apr 2003
    England
    WMS,
    I did actually try a conventional FDD today, when I realised that we were being ripped off. But unfortunately it didn't work I noticed that the ribbon cable seems to fit upside down as well as right way up (theres a piece of the PCB snapped away). Needless to say it didn't work either way, one way it tries to access the FDD on startup (no joy), the other way when we try to access the FDD it says device not ready! It must be something to do with the way the Hitachi operating system works. By the way we made sure that jumper settings were the same on both FDD's all but one that we could not make as there was no where to connect it to.
    Mark...
    If in doubt ask!
    Member wms's Avatar
    Mar 2003
    wyoming
    Bummer!
    Registered hardmill's Avatar
    Mar 2003
    Default Floppy?
    Why not just wire it up to your pc. RS232 or ethernet cable?
    If not have somebody do it up for you. Pay once and
    never deal with it again.
    PEACE
    Registered paulried's Avatar
    Apr 2003
    I just love the "gottcha's" that these manufacturers put into systems. We have a CNC panel cutting machine from Italy. The monitor went on the fritz one day and they wanted $3000 for a 15" tube monitor!!! We almost gave in because to fit into the dust enclosure, you had to have special mounting hardware and just mount the tube (no plastic enclosure). While cursing them we stumbled upon a solution; a flat screen LCD monitor mounted on the outside face of the enclose. $399 and 4 allen screws later we had a replacement and it worked even better than the original since it cut the glare from the overhead lights.
    That was 4 years ago and it still works like a charm.
    Lesson... get mad, curse and get creative!
    Paul Riedlinger
    Let the chips fall where they may...I'm not going to clean them up!
  7. #7
    Member HuFlungDung's Avatar
    Mar 2003
    That's a good one Paul. Sig material even.
    My wife gets mad when I curse but I just tell her the devil keeps interfering until he's gotten me to swear, then after that, things start to click. I'm conditioned like a lab rat
  8. #8
    Registered Klox's Avatar
    Mar 2003
    NZ
    Default floppy drives
    The drives that we uses in todays PC's is "plug and play". That means that the OS reads it easily and sets it up. On the Hitachi edms the stiffy drive is not dedicated as the A drive, this is why the machine will not "pick" it up. You need a stiffy drive that you can dedicate as a B or a D drive. I know that TEAC makes drives with "jumpers" you can dedicate as you need. I know these drives are very scarce these days to come by. Phone all the Computer shops maybe there is one lying around that needs you as the owner. In South Africa a new stiffy costs around R100-00, to replace the stiffy drive on my Hitachi, bying from the agents would be around R4800-00 !!!!!
    I do have sympathy for you
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
  9. #9
    May 2003
    The Pennines, England
    The same problem exists on older Biesse PTPs with CNI controllers. With exactly the same solution that Klox gave. Once again the TAC drive is one of the best options.
    Scrit
    Scrit
    from the Sunny Pennines, England's Backbone
  10. #10
    Apr 2003
    England
    Scrit,
    I have looked at the drive in question and it is a TEAC drive, from the outside it looks identical to a conventional FDD apart from, where the jumper switches are on the back, there seems to be an "extra bit of PCB with an additional jumper attached" I have contacted TEAC with the serial and part no, but they do not recognise it. They said it must be an OEM-Product of another producer. At the moment i'm stuffed! I should probably try what Klox says and try all my local sources, although I don't hold out much hope. Perhaps Hitachi bought all the FDDs to get a "captive audience"
    Mark...
    If in doubt ask!
  11. #11
    Member wms's Avatar
    Mar 2003
    wyoming
    Default Floppy drive help
    Wjman,
    Why don't you post the model number of the drive here and maybe the members could keep their eyes pealed for some.
    And maybe some resourceful member could do a little research as well. The more eyes the better.
  12. #12
    Apr 2003
    England
    Guys,
    The drive is type FD-235HG-6338 TEAC (9826)M.
    PN 193077A3-38. If anyone can find me a couple of replacements for a reasonable price I would be very grateful.
    Thanks Mark...
    If in doubt ask!
  13. #13
    May 2003
    Just Sony and Mitsubishi FDs in my pile, sorry.
    It appears the 235HG model series could run 3 memory capacities, 1MB,1.6MB,2MB. That maybe why there is an "extra bit of PCB with an additional jumper attached" which to select the memory mode. Try contacting www.ezsystems.com/. They sell and repair all kinds of drives. If they don't have the specific drive, maybe they could recommend a replacement.
  14. #14
    Oct 2013
    Default Re: Floppy disk drives
    Replace it by an USB converter.
    No moving parts and it won't care about a little dust.
    Plus it is actually easier nowadays to find an usb key than a 3.5 floppy disk.
Floppy disk drives
Floppy disk drives
