- Schaublin Lathe Bosch alpha parameters
Hello
Sorry my english is not very good, I can´t help you, but I need help for the same CNC in a schublin 102 (turn). Y have one and don´t work. Do you have any manual or information?
Ernesto.
I once got some help from a man at Bosch who repairs the Alpha. I think his name was Herbie but it was a few years ago - I don't know if he still works there.
Robert Bosch Ltd
Meridian Business Park
Leicester
LE3 2WY
Leicestershire
Tel: 0116 281 4488
Fax: 0116 2892878
www.bosch.co.uk
Thanks for the answer.
I´m going to try to comunicate with Herbie. You have any manual or information, because I dont have any one.
Thanks again.
Ernesto
Alpha Bosch
Hi Ernesto,
I have a manual (book) for you, but it is in Dutch. I can send it to
you, but I think you need an English one. But what is your problem, I
have 7 years of experience working and servicing this lathe, so be free to send me your question. By the way, the problem with the parameters is fixed.
(replaced a battery)
Kind regards,
Geert Molema (Spinner560)
Alpha Bosch
Hi Geert,
We buy the machine control with out power supply, now we could fix de power supply and it is working now, the panel control works but we can’t enter the parameters or any thing. I want to know if the control have a proceed to reset or something similar for the first power on.
Kind regards
Ernesto
Parameters
Hi Ernesto,
If you replaced the power supply, then the parameters are gone also. This means you have to enter a few, to make the machine communicate with a pc, or a punch-tape reader.
I am at home right now, spending my holiday. In 3 weeks I'll be back at work where I have my documents about this lathe. But if I remember it right, it was the combination [MODE]+[N1] and then enter 1980. The red display shows you offsets from X-axis and Z-axis. If you enter further (don't bother the offsets) then you get COMMS mode. It 's in your manual also. Use 14 for 9600 Baud. CRT must be also 14. Default is 7 (off). To read in machine parameters use [MODE]+[N1]. To send machine parameters use an old at-pc or max. a 286 with DOS with a special serial cable, or the tape machine. Then use Comms mode 7 for 600 baud. I have original documents, but then you have to wait for a few weeks. If you restart the machine the screen will work. If not, replace the battery under the console from the machine. You can order the parts at FARNELL.(google)
I hope this works.
Greetings,
Geert Molema
Geert Molema
Hi Geert,
I tray to do it, and don´t work. I have a doubt, when you put [MODE]+[N1] you can see some thing in the red little screen, what I see when a start the machine is a message [ 844 parity ], if I press the green key the message is gone, when a press [MODE]+[N1] I don´t see nothing. I think that is not the way the controls have to respond.
Kind regards
Ernesto
Try this
Hi ernesto,
http://www.aggsoft.com/cnc-dnc/bosch-alpha-3.htm
and
http://www.connectcnc-dnc.com/Settin...20Alpha-3.html
This page has info about the cable you must use to communicate with the Schaublin interface. If you receive a parity error, try to clear the memory with G37 (freeing memory) and then G39 (clearing memory). If you press [mode][n1] enter 1980 after it, and then you are in the parameter receiving-mode.
I'll be back in 3 weeks, then I can help you better because I then have access to our manuals and software.
Good luck!
Hi Geert,
Thanks again, I´m going to try.
Have a good holidays.
Kind regards
Ernesto
Hi Geert,
I hope you had have a nice free time.
I still have the problem whith the machine, when a press [MODE]+[N1] I don’t see nothing. I think that is not the way the controls have to respond; Do you know if the control have a secuence to reset or some thing similar?
Kind regards
Ernesto
Does anyone know this type of machines anymore?
Schaublin 102 cnc 1983 model. If anyone has any knowledge about these machines and can help me diagnose a fail in the machine Id love to hear form you.
With kind regards
Valdimar
Were you able to fix the parity error? I am getting the partiy error and it does not respond to 37 or 39.
Re: Alpha Bosch
beste spinner560,
ik heb een schaublin 128 gekocht en ga deze ombouwen naar een modernere besturing.
u hebt geschreven dat u informatie heeft over de alfa besturing en/of de draaibank zelf. heeft u deze informatie nog en zou u dit willen delen met mij.
mvg
Marvin van Nunspeet
Activation process
I'm sorry but I wanted to ask you for help if you can ...
I also have a schaublin 128 cnc that I bought to try to learn ..
The problem is that I have some electrical problems and I do not have the electric manual ..
Do you have this manual?
if so, can you take some photos to see if I can solve my problem?
thanks for listening
I hope I can solve your problem.
Helder Carvallais
Re: Schaublin Lathe Bosch alpha parameters
Hi Everyone.
I've recently acquired a TOS lathe with Bosch Alpha 2 Controller. Anyone has any manuals for this control? Will be most thankful
- You may not post replies
- You may not edit your posts
Forum Rules
