Feed (G01) with spindle off?
Results 1 to 10 of 10
Thread: Feed (G01) with spindle off?
    Registered ghyman's Avatar
    Feb 2005
    Default Feed (G01) with spindle off?
    I have an Okuma Verticle mill w/ a 3000M control.
    I am not able to feed the spindle (G94 + G01) in IPM with the spindle off.
    I've tried M05, M03/04+S0.
    It's all good until it sees the G01. I dimly recall a way to do this on a different control (I believe it was something like G00 F20 or something like that,) but nothing I've tried so far works.
    Is there some quick and dirty way to do this, or do I need to change a parameter... If so, does anyone know which one?
    Registered jackson's Avatar
    Oct 2006
    have you tried not using the G94? or even trying the G94 without the G01 i dont Know okuma, just giving suggestions
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Feb 2005
    Thanks for the reply, but...
    Without the G94, it defaults to G95 (IPR)
    Without the G01, it defaults to G00 (Rapid)
    Dec 2003
    It sounds like the OEM built saftey in, IOW if you command a move with the spindle not running it will freeze, to avoid going into a cut without spindle, or if the spindle stops for any reason the feed stops.
    In IPR it will automatically not move becuse you have no revs.
    It works in G0, becuse the assumption is you will not program to engage the cutter in this mode.
    Registered cadman's Avatar
    Jun 2003
    On the Okuma OSP-P100M controller, M130 allows XY axis movement without spindle rotation (allows broaching, etc..), M131 cancels it. Should be the same for your machine.
    Gold Member
    Jul 2005
    Quote Originally Posted by cadman View Post
    This is not directly related to the topic so I request indulgence.
    You say M130 allows broaching, etc.. This suggests the spindle is being subjected to a vertical load while stationary.
    A while back there was a thread in which I suggested that a spindle could be used for broaching in this manner and the result was a horrified response about bearing damage, etc, etc.
    Does Okuma actually say that broaching is permissible with a stationary spindle?
  7. #7
    Jun 2003
    When you use single point broach tools, like PH Horns, you only take .002 - .003 per pass. Depending on the material you are cutting, hardly any force at all. Keep in mind, there is more bearing contact with forces in the Z axis as opposed to the X&Y axis, and more preload also. Okuma spindles especially are extremely rigid. Nowhere in any of our Okuma documentation do they advise against broaching.
    If you have a spindle faster than 15K I wouldn't broach. As the RPMs go up the spindles tend to be more fragile and the reason for getting those fast spindles is for HSM anyways, not second op work.
  8. #8
    Jan 2007
    U.S.A.
    We have done a decent amount of broaching with our Okuma, no problems. That was using the same M130, on a OSP5000M, so the code should be fine.
  9. #9
    Gold Member
    Jul 2005
    Thanks. I have not done any broaching yet but it was my feeling that the forces would be low compared to what the spindle bearings could handle even when stationary. I have Haas not Okuma so I have not seen the M130 code.
    Regarding running a feed motion with a stationary spindle I find that if you have spindle orientation it is possible; orient the spindle and then feed.
  10. #10
    Feb 2005
    Sorry... nogo on the M130.
