May be here:
DNC software. CNC and DNC settings for Fanuc 0-P.
Hi All,
This is my very first post. I really need some help regarding setting up a DNC for a Fanuc series OO-P.
I would need to know what parameter numbers to change. Could someone please help me on this. I found a lot of documentations online with settings to change but, I figured that these settings are machine specific. I could not find any documentation for Fanuc Series OO-P.
I will be very greatful for your help on this regard.
Kind Regards and Thanks
Christi Das Devathala
May be here:
Arthur Grasin, AGG Software
(DNC Precision, CNC Syntax Editor at http://aggsoft.com)
Hi aggsoft,
Thank you for your prompt reply. The solution in the link you have sent is exactly what I have done. No Joy.
I figured that setting PARAM #340 and #341 should set the communication path, but seems like this is not happening. I looks like more of a hardware issue. I also need to examine the PC code in the machine. I guess its not setting the correct bit
Please lets us know, if you have come across other issues on this regard.
Hi cddevathala
I have too a machine used FANUC 00-P as same as your machine. And i don't know configure these parameters in order to communicate with DNC.
Because i tried parameters for FANUC 0-P but can't transmit program to machine.
So did you fixed your error?
Please help me. Thank you.
