Brilliant!
A work of great care and patience I imagine to get the silver wire embedded without breaking the egg?
And what glue to hold it in place?
Cheers
Roger
Silver wire embedded goose egg shell
The first trial
0.2mm silver wire.
Brilliant!
Cheers
Roger
Engraved flower + Pressed flower
Another first trial
Thank you for posting all of this great artwork. Like many others, I am amazed.
Looking back at the egg that you drilled with so many holes, you mentioned that there were some challenges with holding tolerances. Do you think that the process of drilling the holes might have shifted the egg's surface around vs the original scan?
My wife is not usually that interested in CNC, but I am definitely going to show her this thread.
Some chicken eggs
Thin delicate chicken eggs? OK, that is special.
You have the surface-following down to microns.
Wonderful!
Cheers
Roger
Another Assyrian egg
Have you thought of using air-gauging with a small orifice? Since the probe does not touch the surface you could actually spin the egg while measuring. Hum ... now try getting the data back into Mach. This could be tricky. ModBus might work. Some experiment needed.
With the speed of air sensing you could make multiple scans of the surface and average.
Cheers
Roger
That fast? Fair enough: you don't need the complexities of air gauging.
Cheers
Roger
I hope you post more details about your process. Very inspiring!
[QUOTE=uvvvvw;1817238]Thx Victor.
how you can remove the ready egg?
[Just melting the glue]
what diameter that tool you are using?
[For relief engraving -- 0.2mm 30 degrees flat tip engraving tool]
[For hollow out -- 0.6mm PCB rout bit][/QUOT
Hi I like this machine and I'd like to buy it .would you tell me more details about this? How much it costs and which country is this from ?or which Brand?
H.kgh.st94@gmail.com
Emu eggshell
3 colour layers
Fragility VS Flexibility
Another spring
Fossil Fishes
My favorite Dinosaur Baby
