CNC egg shell carving - Page 10
Page 10 of 10 FirstFirst ... 78910
Results 109 to 115 of 115
Thread: CNC egg shell carving
  1. #109
    Gold Member
    Jun 2010
    Default Re: CNC egg shell carving
    Thin delicate chicken eggs? OK, that is special.
    You have the surface-following down to microns.
    Wonderful!
    Cheers
    Roger
  2. #110
    Nov 2015
    Another Assyrian egg
    CNC egg shell carving-asshur02-jpg
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-asshur02-jpg
  3. #111
    Gold Member
    Jun 2010
    Have you thought of using air-gauging with a small orifice? Since the probe does not touch the surface you could actually spin the egg while measuring. Hum ... now try getting the data back into Mach. This could be tricky. ModBus might work. Some experiment needed.
    With the speed of air sensing you could make multiple scans of the surface and average.
    Cheers
    Roger
  4. #112
    Nov 2015
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Air gauging method is a bit too sophisticated for me
    Right now, it took me 15 minutes for 1500 points. It is quite OK for me already.
  5. #113
    Gold Member
    Jun 2010
    That fast? Fair enough: you don't need the complexities of air gauging.
    Cheers
    Roger
  6. #114
    Jan 2015
    I hope you post more details about your process. Very inspiring!
  7. #115
    Nov 2015
    Quote Originally Posted by JimInAshland View Post
    Here a bit detail of it.
