New Wizard - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 77 of 77
Thread: New Wizard
  1. #73
    Dec 2007
    I know this is an old thread but I'm hopful that someone's watching. I just downloaded the plugin and when I fill everything in and click Post Code nothing happens. I don't get any code. Here's the screen shot of how I completed the form.
    Attached Thumbnails Attached Thumbnails New Wizard-document-pdf
  2. #74
    Oct 2006
    I have a couple of questions. The first is the obvious. Did you put the macro files in the proper folder? When you click to post it should be running the Macro and it apparently is not. Another possibility is that you use a custom profile. If that is the case then the macro needs to go into the macro folder under the custom profile name in your Mach directory.
    Hope this helps. I haven't looked at this stuff for a while
  3. #75
    Dec 2007
    That was it. I have a custom profile. I moved the files and it works great. Thanks for an awesome app!
  4. #76
    Dec 2006
    Default Great Wizard.
    Thanks very much for sharing your circle routine. The graphics are great and the program works great. I wish I could do so well.
    For those who are running Mach3 with the Syil X3 configuration setup, the "M700.m1s" file has to be in Mach3--->Macros--->SyilAmericaX3. Then things will work great.
    Thanks again.
    OM
  5. #77
    Feb 2005
    Indonesia
    Default Rectangular multiple drill update ?
    Is there a better wizard/plugin tHat I do not know of rather than the one already on the wizard ?
    That's the only one that can not "save" the input after you exit the wizard ?
    I need to drill many holes in rectangular shapes, very quickly.
    There is no "save" button on the rectangular drill wizard.
    So everytime i enter I have to input all over again.
    I hope that's the old version of the wizard.
    Help ....
    C
New Wizard
New Wizard
New Wizard
