I've been setting zero with a probe for several years now and want to do a 3d digitizing scan using Mach3 Digitizing wizard. When setting zero the probe touches and retracts just fine. My problem is when the probe signals a touch when using gcode generated from the wizard the run stops as if it hit a limit switch but the reset button is not flashing. I have an ESS and G540 and the probe setup as port 2 pin 15. The LED on the probe lights up fine and shows up in the diagnostics screen. What might I have setup incorrectly?
