I need help with setting up a touch off plate in Mach3. I have tried several versions of the macros for the touch off plate with no luck. At first the macros all the different macros would work but I was not able to get them to go to the correct z zero height. This was due to the fact that the touch off setting was set to say (not exactly sure of what I had for numbers) go .04 above the probe and then go minus the .76 for the touch plate plus the .04. However, the z would move .1 above and then add the .76 and only go down the .80 and set above the work surface. Now, the status line in Mach 3 just shows that it is working and I can't do anything without hitting the reset.
Any help would be appreciated. I asked Mach3 support for help and they just said do a google search for my problem
