Need Help! Mach3 + big tex tool change zero issue
Results 1 to 3 of 3
Thread: Mach3 + big tex tool change zero issue
    Mar 2018
    Default Mach3 + big tex tool change zero issue
    Hello,
    i have an issue with my tool change using the big tex screenset with the tool change zero. Issue is when i do a tool change with a tool longer than the previous one, (the inverse is also true but do not engage issues), when i cycle start, mach 3 will try to position the tool for the next operation, it seems that it will also doma upward move to compensate for the new longer tool. Since my tool change are done at Z=-15mm, lowest i can so i can insert back the dust boot, if the difference between the new tool and previous tool is more than 15mm, mach will move up untill it trigger the limit switch.
    Is there a workaround ?
    thanks
    Hugues P
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Mach3 + big tex tool change zero issue
    The quickest workaround would be to start using soft limits (which is a good idea anyway). Other than that, look at your tool change macros, see what they do and implement some Z position checks.
    Mar 2018
    Quote Originally Posted by CitizenOfDreams View Post
    Thanks, just started to use uccnc, i had to many random issue with mach3.
