Problem with ATC Macro
Results 1 to 5 of 5
Thread: Problem with ATC Macro
    Feb 2006
    UK
    Default Problem with ATC Macro
    I have a macro working a 8 position ATC on a Boxford 160 lathe. The problem is that sometimes maybe every 8th change or even every 2 changes the X and Z fail to move to the safe position prior to the change but the change still takes place In the message screen it shows " cannot use G53 incremental Block = G0G53Z0.0000
    I can't see this G53 code anywhere in the macro (below) Can someone offer up any suggestions to why this is happening?
    thanks
    Jason
    'This macro drives an 8 position stepper driven ATC.
    'It drives forward past a ratchet, then backwards a little to stall the motor
    'The Y axis is setup for 20 steps per mm, my ATC requires 900 steps per index
    'of 45 degrees.
    'Because of the stall, steps are lost. So, we switch to INC mode for the ATC,
    'then back to ABS mode before we exit.
    'OEMDRO(1200) is utilized to store the last used tool (OldTool) and is updated
    'upon final execution of the macro. This is resorted to as the Txxyy will overwrite
    'the "CurrentTool" DRO.
    'The Y axis is zeroed if tool is Number1, to prevent an overflow of the DRO after
    'multiple changes.
    'M6Start.m1s
    Message ("macro running")
    OldTool = GetOEMDRO (1200)
    Tool = GetSelectedTool()
    MaxToolNum = 8 'Max number of tools for the changer
    If OldTool = Tool Then
    Message ("Selected Tool already loaded")
    Exit Sub
    End If
    While Tool > MaxToolNum
    Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
    Wend
    xval= getoemdro(800) 'get x
    zval= getoemdro(802) 'get z
    Call Dooembutton(138)
    While IsMoving()
    Wend
    moveto = Tool- OldTool
    If moveto<1 Then moveto=8+moveto
    code "G91" 'inc mode
    code "G00 Y"+Str((moveto*45)+5)
    While IsMoving()
    Wend
    code "G00 Y-5"
    While IsMoving()
    Wend
    code "G01 Y-2 F100"
    While IsMoving()
    Wend
    code "G90" 'abs mode
    NewTool=Tool
    If NewTool=1 Then
    Call DoOemButton (1009) 'zero Y
    End If
    Call SetUserDRO (1200, NewTool)
    SetCurrentTool(NewTool)
    code "G0 Z"+Str(zval) 'return to initial position
    code "G0 X"+Str(xval) 'before tool change
    While IsMoving()
    Wend
    Feb 2006
    UK
    Default Re: Problem with ATC Macro
    After some testing I have found a pattern to this problem but I'm no closer to understanding why it's happening.
    It seems that on every 8th turret index I end up with the "cannot use G53 incremental Block = G0G53Z0.0000" So, this could be two tool changes for instance tool from tool 7 to 6 and then 6 to 7 so eight indexes in total I'll get the error message. Or 3 to 4 then 4 to 5 then 5 to 6 then 6 to 7 then 7 to 8 then 8 to 1 then 1 to 2 then on the 2 to 3 I'll get the error message. what ever happens on the 8th tool position I'll get the message and the XZ won't move to safe position but the change still happens..
    Help!
    Feb 2006
    UK
    OK some further information that may help someone to help me!!!
    It seems the cause in this part of the macro:
    NewTool=Tool
    If NewTool=1 Then
    End If
    Where is says "If NewTool=1 Then" I changed the number 1 and the macro seems to work fine as long as the number put in is higher than 8. Of course the DRO is not resetting when tool 1 is selected so this will cause the DRO to overflow.
    Does this give any clue?
    Aug 2017
    Hi JETREBEL
    Any luck with the macro? I have a Boxford 240 TCL and having a similar problem with my ATC.
    Star
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    There's probably a macro in Button 1009.
    UCCNC 2017 Screenset
