Running Mach3 with a Step four router
Results 1 to 7 of 7
Thread: Running Mach3 with a Step four router
    Jun 2008
    holland
    Default Running Mach3 with a Step four router
    Hello
    After some passive use of CNC zone forum
    i am having a problem which i cannot solve by myself.
    A good reason to step in!
    I am currently running my Step4 precise 760 router with mach3.
    It was quite easy to get the XYZ Axis working with the Step four SF-C2 controller. but here it comes!
    I do also have a SFC-160 spindle controller which connects to the
    SF-C2 box with a serial connector.
    i cannot figure out how to get the spindle working with Mach3
    I,ve found a lot of data on the internet about ports and pins, but
    not one file shows the actual signal flow of the SF-C2 controller,
    or the pin settings, and signals that are used to steer the spindle.
    Does anybody know how to configure this setup?
    Best regards
    Bram
    Oct 2008
    CYPRUS
    Default need help with my step four
    Hello,
    need help in setting up my step four basic540 working with mach 3.
    Need to configure ports pins etc.
    thanks in advance
    Jun 2008
    holland
    Hello Floros
    to drive the XYZ axis from your 540 with mach 3
    you need to set pins as following.
    ////////// Step // Dir ///////////
    X axis pins 2 and 3
    Y axis pins 4 and 5
    Z axis pins 8 and 9
    Pins 6 and 7 can be configured for relay switching.
    Best regards,
    Bram
    Oct 2008
    CYPRUS
    Thanks a lot Bram.
    I will give it a try tomrrow and let you know if is working
    Regards
    Floros
    Registered DennisCNC's Avatar
    Aug 2005
    I looked at the step-four site....What type of spindle is it? DC or AC vfd controlled, other? put up a picture of the spindle and controller that will help a lot.
    Dennis
    Aug 2017
    Spain
    Default Re: Running Mach3 with a Step four router
    Quote Originally Posted by B-Sure View Post
    Hello
    Best regards
    Bram
    Hi Bram!
    I know it's been a long time since you posted this but did you make any progress with the machine?
    I just bought a Step-four Basic 540 with the SF-C2 controller and the SFC-160 spindle for 200€ and I'm trying to figure out if I can make it fully operational with Mach3.
    Thanks!
  7. #7
    May 2022
    Quote Originally Posted by rpbenito View Post
    Hi Bram!
    Thanks!
    Hola !! Tengo una cnc stepfour y ahí estoy con ella moviendola con mach3. ¿Quieres que comentemos sobre ellas? Gracias ||
