Most likely, you're getting noise. On the general config page, put 5000 in the debounce box in the top right corner and see if that helps.
I’m still working on my first project, a Chinese symbol meaning Happiness for a friends wedding. So far it has not been bringing any happiness into my life. But like I said this is my first project and just going through a period working out the bugs.
Using Mach3
Windows XP
The code is attached below
When I start the cut it will run for a while and all of the sudden I get a “Limit Switch Triggered” error message.
When it gives this error message I am not near any limit switches. And if I run it with the Diagnostic screen displayed, the Limit Switch Leds never flicker and I will still get a “Limit Switch Triggered” error message.
It doesn’t happen at the same place but in random places on the cut.
I then do a “Reset”.
Then press Start, and it doesn’t start cutting where it stopped. It skips several lines of code and starts cutting again.
Any suggestions?
Hager
G0 Z0.1250
G0 X0.0094 Y1.4181 Z0.1250
G1 X0.0094 Y1.4181 Z-0.1250 F10
G1 X0.3848 Y1.8189 Z-0.1250 F20
G1 X0.7603 Y2.0192 Z-0.1250
G2 X1.5111 Y1.6185 Z-0.1250 I0.1554 J-0.6126
G1 X1.5111 Y1.6185 Z-0.1250
G2 X0.7603 Y-0.1849 Z-0.1250 I-3.1323 J0.2462
G1 X0.0094 Y-0.7860 Z-0.1250
G1 X-0.7415 Y-0.1849 Z-0.1250
G2 X-1.4923 Y1.6185 Z-0.1250 I2.3814 J2.0495
G1 X-1.4923 Y1.6185 Z-0.1250
G2 X-0.7415 Y2.0192 Z-0.1250 I0.5955 J-0.2119
G1 X-0.3660 Y1.8189 Z-0.1250
G0 X0.0094 Y-4.9939 Z0.1250
G1 X0.0094 Y-4.9939 Z-0.1250 F10
G1 X0.3848 Y-4.5931 Z-0.1250 F20
G1 X0.7603 Y-4.3928 Z-0.1250
G2 X1.5111 Y-4.7935 Z-0.1250 I-0.0914 J-1.0750
G1 X1.5111 Y-4.7935 Z-0.1250
G2 X0.7603 Y-6.9976 Z-0.1250 I-1.7533 J-0.6326
G1 X0.0094 Y-7.5988 Z-0.1250
G1 X-0.7415 Y-6.9976 Z-0.1250
G2 X-1.4923 Y-4.7935 Z-0.1250 I1.0025 J1.5715
G1 X-1.4923 Y-4.7935 Z-0.1250
G2 X-0.7415 Y-4.3928 Z-0.1250 I0.8423 J-0.6743
G1 X-0.3660 Y-4.5931 Z-0.1250
G0 X0.0094 Y-7.9995 Z0.1250
G1 X0.0094 Y-7.9995 Z-0.1250 F10
G1 X0.0094 Y-7.9995 Z-0.1250 F20
G2 X-2.6186 Y-3.5913 Z-0.1250 I0.2802 J3.1546
G1 X-2.6186 Y-3.5913 Z-0.1250
G2 X-0.7415 Y-3.1905 Z-0.1250 I1.2307 J-1.1677
G1 X-0.7415 Y-3.1905 Z-0.1250
G1 X-0.7415 Y-2.6896 Z-0.1250
G1 X-2.8063 Y-2.6896 Z-0.1250
G2 X-2.9941 Y-2.4892 Z-0.1250 I0.1036 J0.2852
G1 X-2.9941 Y-1.6376 Z-0.1250
G2 X-2.8063 Y-1.4372 Z-0.1250 I0.1727 J0.0263
G1 X-0.7415 Y-1.4372 Z-0.1250
G1 X-0.7415 Y-1.1867 Z-0.1250
G2 X-2.4309 Y2.8207 Z-0.1250 I0.9383 J2.7554
G1 X-2.4309 Y2.8207 Z-0.1250
G2 X-0.7415 Y3.2215 Z-0.1250 I1.1394 J-1.0418
G1 X-0.7415 Y3.7224 Z-0.1250
G1 X-2.8063 Y3.7224 Z-0.1250
G2 X-2.9941 Y3.9228 Z-0.1250 I0.1036 J0.2852
G1 X-2.9941 Y4.6241 Z-0.1250
G2 X-2.8063 Y4.8245 Z-0.1250 I0.2008 J0.0000
G1 X-0.7415 Y4.8245 Z-0.1250
G1 X-0.7415 Y5.3254 Z-0.1250
G1 X-2.0555 Y5.3254 Z-0.1250
G2 X-2.2432 Y5.5258 Z-0.1250 I0.1036 J0.2852
G1 X-2.2432 Y6.2271 Z-0.1250
G2 X-2.0555 Y6.4275 Z-0.1250 I0.2008 J0.0000
G1 X-0.7415 Y6.4275 Z-0.1250
G1 X-0.7415 Y7.8301 Z-0.1250
G2 X-0.5538 Y8.0305 Z-0.1250 I0.2008 J0.0000
G1 X0.0094 Y8.0305 Z-0.1250
G1 X0.5725 Y8.0305 Z-0.1250
G2 X0.7603 Y7.8301 Z-0.1250 I-0.0131 J-0.2004
G1 X0.7603 Y6.4275 Z-0.1250
G1 X2.0743 Y6.4275 Z-0.1250
G2 X2.2620 Y6.2271 Z-0.1250 I-0.0131 J-0.2004
G1 X2.2620 Y5.5258 Z-0.1250
G2 X2.0743 Y5.3254 Z-0.1250 I-0.2913 J0.0848
G1 X0.7603 Y5.3254 Z-0.1250
G1 X0.7603 Y4.8245 Z-0.1250
G1 X2.8251 Y4.8245 Z-0.1250
G2 X3.0128 Y4.6241 Z-0.1250 I-0.0131 J-0.2004
G1 X3.0128 Y3.9228 Z-0.1250
G2 X2.8251 Y3.7224 Z-0.1250 I-0.2913 J0.0848
G1 X0.7603 Y3.7224 Z-0.1250
G1 X0.7603 Y3.2215 Z-0.1250
G2 X2.4497 Y2.8207 Z-0.1250 I0.5501 J-1.4425
G1 X2.4497 Y2.8207 Z-0.1250
G2 X0.7603 Y-1.1867 Z-0.1250 I-2.6278 J-1.2521
G1 X0.7603 Y-1.4372 Z-0.1250
G1 X2.8251 Y-1.4372 Z-0.1250
G2 X3.0128 Y-1.6376 Z-0.1250 I0.0150 J-0.1740
G1 X3.0128 Y-2.4892 Z-0.1250
G2 X2.8251 Y-2.6896 Z-0.1250 I-0.2913 J0.0848
G1 X0.7603 Y-2.6896 Z-0.1250
G1 X0.7603 Y-3.1905 Z-0.1250
G2 X2.6374 Y-3.5913 Z-0.1250 I0.6465 J-1.5684
G1 X2.6374 Y-3.5913 Z-0.1250
G2 X0.0094 Y-7.9995 Z-0.1250 I-2.9083 J-1.2537
UCCNC 2017 Screenset
I had the same problem before, and even tried setting the debounce up a bit. Now, although the limit switches are installed, and used as homing switches, I have limit switches turned off in Mach. That gremlin will pester me no more...
When I installed my switches I used coax and grounded them, as I had read about problems like this. I even set debounce to 5000 and still get a false trigger once in a while. And every time I reset Mach3 it would skip a few steps, which is not a good thing.
I'm thinking of turning off the switches as limits and using it as Homing Switchs as you have.
When you use them as homing SW's does the interference give you any false signals?
Never...
My cables have a grounded shield as well, but with 20 foot servo power wires in the near vicinity, I have always been plagued by this.
I have watched the diagnostics screen in Mach when it trips, and the light does not blink for any of my limit switch inputs, so it is happening very fast. (hence, the debounce method)
I simply became tired of my machine quiting on me, since it runs about 4 hours a day. Plus, I work well within my machine boundaries and use caution when jogging near my limit switches, so this is the right answer for me (until I buy a $200,000 router, that is.)
Good luck,
Rob
i'm having the same problem here too.
where are you grounding your wires out to? maybe i need to improve this area on my machine.
5000 didn't seem to help much for me
I had the same problem. I put a .01 mf capacitor across the ground and signal pins for the limit switches. (found this in another thread here) No more problem. I tried several debounce settings never found one to completely eliminate the problem for me until the cap was added.
Not stepper wires. Limit switches.
Use one cap per input. So if all limit switches are in series to one input then use one at the input.
If each switch has it's own input then one per switch.
Greg
There will be more qualified people to answer this but here is my take.
A capacitor will pass AC but not DC. Noise tends to be AC in nature so gets passed to ground or filtered. So the input does not see it.
However the DC signal is not affected except for a very short delay.
The cap needs to appropriately sized for the situation to have this effect.
That is probably over simplified but is my way of understanding it.
Greg
The cap stores a small amount of electricity, and when the switch is made, it discharges causing a slight surge in voltage. Most of the limit switches used on hobby machines, and even my old Digital Tool machine are 5 volts. The 5 volts are not enough to keep the contacts clean, which according to Mariss from Gecko, helps contribute to the noise problem within the switch. It worked for me as far as the false triggers, but I now have a problem with repeatability. I am in the process of designing and building optical switches to correct both problems.
Mike
No greater love can a man have than this, that he give his life for a friend.
optical would be a great solution. i was hesitant to do that because of cost, but i'm sure if you are crafty there is a low cost solution.
for now i've added caps, and that has helped alot.
The caps help with the noise as Greg explained.
The optical switches would probably be more accurate if you are using some of the swithces as home switches and require more accuracy. For limits you don't need that much accuracy. I don't think the optical switches will make much difference with noise.
Well according to the electrical guy helping me with these, they are immune to noise. Now whether or not that is correct is yet to be seen but I can tell in in a week!
My noise problems were corrected with the caps. The optical's are for accuracy. I am using some military surplus switches that the electrical guy tracked down and found the manufacturer, and they told him the switches are accurate to within .0001". They were used in aircraft applications!
Mike
The optical part is obviously immune to noise, but you can still get noise in the wires. Industrial proximity switches and the like are normally powered by 24V DC which is much more resilient than 5 V as far as noise is concerned. If you use shielded cable and 24V signals, you should have much less trouble with noise.
Matt
Broadly speaking there is two contributors to noise problems in the typical homebuilt regarding limit switches running 5v.
The first is oxidation build up on the NC contacts. This is caused by typically using switches that are rated for 10 or more amps then running a few milliamps through them.
This can be helped by placing a 0.01uf cap across the switch which helps to keep them clean. Optical switches will of course help here, no mechanical contacts.
Better still run 24v through them. 24v is fairly typical on big dollar machines.
The second source is wiring acting sort of like an aerial. Shielding can help here. As will a filter cap on the input. Also a debounce setting in software.
Greg
