I will tell you right now that optical switches are not immune to noise. That is simply not true. I use the optical switches from Industrial Hobbies and am having the same problem as yall are. IH's solution was to make sure everything is grounded properly, and if that doesnt work, to use a resistor from each input to ground. A 1/4w 100k or 1000k is what they recommend I believe. I will say that the optical switches are just freaking amazingly accurate. And IH's are beautifully made.
pzzamakr please note I said I didn't know if the statement was correct, but that I would find out. Sounds like you already have. I am curious about the IH switches. I am trying to build my switches now because I couldn't find the IH switches. Are they still available? I looked on their site again last night and could not find them listed???
Mike
No greater love can a man have than this, that he give his life for a friend.
Yeah, just call em. Gene is great and I'm pretty sure he said they were available for purchases seperately from the system. But dont take my word on it. And yes, I should have been more specific, the switches themselves are immune, but since you have to wire them, connect them, etc. etc, they are then not immune.
Hi, I just saw this posting and simulated your Gcodes. If it is not yet finished, you may want to edit it. The 1st horizontal line should be longer than the 2nd horizontal line. In other words, you reverse the 1st and 2nd line's length. Also, traditionally, you put two of those side by side to mean "Double Happiness" as it means bringing happiness to the 2 families of the couple.
Hope this helps.
+1
Hi All,
Thanks for sorting one problem but I have another, I have tried wiring my limit switches to my Geko 540 one wire to outlet 1 and the other to common but can't get it to work what have I missed??
Mike
