I have an issue with diy hand wheel. I'm using 5v 4 pin hand wheel and few buttons for axis/speed control, pulled to ground to enable option. I can see wheel responses, axis and speed switches behavior when I get in RNR plugin config. Buy mach3 doesnt react on any of those. MPG1 enabled it mach3 settings.
So it definitely some settings in mach3 I am missing. But I cant find out which one.
Any help would be highly appreciated
Re: Mach3+RNR USB controller+ diy handwheel problem
Using a RnR EcoMotion Card Board I make that.
A) Plug the cables from the MPG to the card board.
B) You Must use a Specific Plugin: [BSMotion-v2.dll]
C) You Must Allow [MPG #1] on screen: Config >> Port and Pins >> [Encoder / MPGs].
D) You Must Allow the Digital Inputs on screen: Config >> Port and Pins >> [Input Signals]
* [OEM TRIG #1] --- Port #3 --- Pin Number 5
* [OEM TRIG #2] --- Port #3 --- Pin Number 6
* [OEM TRIG #3] --- Port #3 --- Pin Number 7
* [OEM TRIG #4] --- Port #3 --- Pin Number 8
