Chech this out: https://www.machsupport.com/forum/in...5104#msg265104
Does anyone have a wiring schematic for adding a laser to a cnc router.
I am running mach 3 which will probably be controlled via ttl to ground. I do not have an ethernet card so I believe pwm is not possible.
I am running a gecko g540 card.
The ttl needs 5v which I believe I might have to supply that with a buckboard off the 48v power supply.
The only control I have over laser power is the hand adjustable pot which is used for focusing so I don;t believe I can do greyscale.
Any help is appreciated.
- Newbie- Commercial laser cutter that allows direct control of the laser and position controls
- Need Help!- Where can I buy laser power control board for 40w MoshiDraw laser machine
- Laser cutter software RDworks v8 tutorial 18 How to control the laser machine from th
- Laser control board, 6c6879-laser-M2:2 no dongle
- Using Flashcut CNC Spindle rotate card control to control laser power
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
