I haven't ordered one of these, yet. And, this is why. Before ordering, you need to know what kind of mpg connection your controller is designed for. Likely, there is no existing port for an mpg. That means that you have to open up the box and look for the mpg connection point. Maybe you'll get lucky and there will be a USB port that you can use. Then, you just have to make an opening for the cord. Just be sure to get a rubber grommet. It should be a tight fit all around. If no USB connector, it may require a pin type connector.
G is ground, +5 is the voltage. It's pretty straight forward.
Since the Chinese manufacturers are cheap, you can almost bet on the controller board having one connection or the other since they offer them with and without mpgs. Lower cost to use one board than many.
