You can do it any way you want. You just need to write your M6 macro to switch axis during the tool change.
(using google translator) I have a 3 axis CNC for woodworking, I intend to put 2 spindle motors on the Z axis to work independently with 2 different cutters, let's say, the first spindle would mill the part and the second spindle would cut, both working in sequence , question is, what changes do I need to make in mach3? should I use pneumatic drive in conjunction with the ball screw? any help is welcome
- Ruida controller for double head laser with two independent axis
- Need Help!- 2 X axis, independent but simultaneous, cutting plotter. How?
- Moving Part Independent of 4th axis tbl *Tormach*
- Configuration of Fourth Axis Configuration(Rotation of 360 degree z Axis)
- Dual Steppers or Timing Belt for Dual X-axis?
UCCNC 2017 Screenset
could you tell me how to configure this?
It depends on your mechanical design.
What you do, is during a tool change, determine which spindle will be used, and do a G52 offset to make the current spindle aligned with the part.
If using pneumatic cylinders to raise and lower the spindles, then you simply raise and lower the appropriate spindles.
If using separate motors and screws, you might consider using Mach3's Swap Axis command to make the current spindle the Z axis.
The machine today has only 1 cutting motor on the z axis, I intend to add another cutting motor, this one working with a pneumatic system, using the same wax spindle as the first cutting motor. so there would only be 1 command on the z axis with stepper motor and 1 pneumatic
